wireless charging
Jul 25, 2013
11
Hey guys could you you give me a link of the least expensive quality wireless charging pad for the new nexus 7. Thanks a lot guys.
The size of the charger should not matter. But you will have to position the Nexus' charging coil over the charger's coil. This may require a bit of sliding the table around until it goes into charging mode. I have to do the same thing with my phone (Droid DNA). On the DNA when you have it aligned a LED lights up and a charging message appears on the screen.
I was just looking up qi chargers on amazon. Added a few to my wishlist.
This one is made by Ankr, the company that makes all those usb charging hub things. I've never used one, but they have great reviews on all their products. $50
Amazon.com: Anker? Qi-Enabled Single-Position Wireless Charger Charging Pad - White: Cell Phones & Accessories
This one is made by a company called Lugulake. $36.. I want to get this one but I'll need to see more reviews before I order one.
Amazon.com: LuguLake Qi-Enabled Single-Position Wireless Standard Charger; Supports For Samsung NOTE3, Galaxy S4 ; Nokia Lumia 920, Lumia 820; HTC Droid DNA, HTC 8X, HTC Rzound; Google Nexus 4, Google Nexus 5; LG D1L, LG LTE2; Sharp SH-07D, Sharp SH-
Lastly the LG WCP-700, probably the best Qi charger you can buy $90 ($70 on the LG Website) ($50 Refurb)
Amazon.com: LG WCP-700 Portable Power Mat Home and Office Charging Pad: Cell Phones & Accessories
Check out the LG WCP-400. Available from most Verizon stores retail for $40, it's one of the easiest ones to find. Works perfectly with my Nexus 4. I'm not sure how well the Nexus 7 balances on it yet; waiting for the LTE model to show up before I order one.
just tried my new zen version charger. it dinged and started charging. i can test it overnight tonight.[URL="http://shop.mobilenations.com/zens-wireless-single-charger/5A233A14193.htm"
I know a phone can wireless charge with a case on it. So can new Nexus 7 wireless charge with a case or just without? Thanks.
I just purchased the Nexus 7 thismorning from BestBuy... Tried using Verzion's fatboy pillow (my wife uses to charge her dna with). Didn't get any indications it was charging the table.
How does that charger work for the Note 3 when that device hasn't even been released or mentioned yet?
The Nokia dt900 and dt910 work fine. But, I had to put the tablet in landscape so it did not slide off with the dt910
shawnjosecrespo
