wireless fast charger slow
Eric Lipkind
60
I am using the wireless fast charger. I have 2 actually. They both charge very slow - certainly not fast charging speed. In the Note 7, the charge was very fast. Any idea how to fix?
I also have the LED case. On one charger, the charging stops when the case is closed. I can't figure out why this only happens on one.
Wireless fast Charging will no be as fast of a charge as wired. I don't Wireless charge much due to it being slower. When I need a quick charge before going out I plug it in to my micro USB. If I need to charge it at night I throw it on my wireless charge before bed
I just upgraded to the S7 Edge, the wireless Fast chargers I have with the stands charge really slow. The flat one's work a lot better but are still slow. I called Samsung, they are going to exchange them. The phone does charge a lot faster plugged in. Samsung installed an old software program for these chargers instead of using better software because they were shipping the phones all over the world and some places can't use the better software. Call Samsung and complain.
I have the stand and mine charges my S7 Edge from 5% to 100% in about two hrs. When plugging in the USB charger, it takes about 90 minutes.
Like others have said, If I need it to charge faster, I plug in the cable. If overnight, I use the wireless. I'm happy I have both options.
It's still faster then what it takes to charge my iPhone 6S+.
The strange part is that it went really fast with the Note 7, so I wonder if it's a function of the S7 Edge. I'd love to hear if anybody has experience with them charging fast.
My fast chargers require a qc 2.0 power adapter to power the wireless charger. Are you guys using that for your fast wireless charging? Does your phone display "fast charging" when it is charging? Also make sure "fast wireless charging" is enabled under Settings>Accessories.
I'm using the adapter that came with the chargers. The phone does not say 'fast charging', but it doesn't say that with the wired cord either. My Note 4 did though.
My S7 Edge and Note 5 both say wireless fast charging when I place them on the wireless stand. Wireless fast charging is obviously checked since it says it is fast charging. The wireless fast charger just takes about 30 minutes longer then plugging in. That's just how it is.
Yup. The fast wireless charging is significantly faster than regular wireless that I had on previous phones. Ultimately it's not that much slower IMO compared to wired.
Use the power adapter that came with your edge. It should be qc 2.0 and you should see it show as fast wireless charging if your wireless adapters are indeed fast wireless chargers.
I compared the fast charger that came with the wireless charger to the one that ships with the S7 Edge and they are identical, same with the Note 5 fast charger. It doesn't matter what charger you use since they are the same. The output numbers are the same.
That two hrs that my S7 Edge has shown it would take to charge now turned into three with 19 minutes to go.
Go into battery settings and make sure the options are selected
That's if your fast wireless charger came with an adapter. The one I got from amazon only came with a cable but no adapter.
I see you use a VPN, I have been debating on using one to stream NHL games that are blacked out by the cable providers.
What are u using it for? Just privacy purposes?
That VPN is created by Adguard. It's how it blocks ads in apps and anywhere else on my phone.
