- Feb 10, 2011
- 93
- 0
- 0
I'm looking for a wireless home phone device (I don't need internet) that I can put an existing active AT&T LTE SIM in and hopefully continue to use that line on my Mobile Share Value plan. The one device that AT&T sells is out of stock (and might require its own separate plan?). Any suggestions for alternatives?
I basically need to feed that cell line via the house phone wiring to a cordless phone base, to make it easier to deal with calls on that line (the calls are often are for both of us, and doing a 3-way call each time is a bit of a hassle).
Thanks.
(apologies if this is a repeat, when I posted last night all I got was an empty page after clicking "submit new thread", not sure if it was because I had a URL in my post, or perhaps the new DDoS checking screwed something up)
Thanks.
