Hello all!
Today I'd like to present you one more application. It will be especially interesting and useful for those who have babies and small kids.
This application represents a wireless baby monitor. It is one of the best in its category. The main features of this application are high stability, saving power battery usage and there are also a number of unique functions.
Please read attentively Help before using it.
Specifics (in brief):
-"Call me back" function;
-Sensibility level tuning;
-SMS about low battery;
-SMS about missed calls (for the PRO version only);
-Two way talkback (for the PRO version only);
-SD card installation.
General:
To activate Nanny, use the ?begin? item of the menu. Then you should input or choose a phone number from the list of your phone contacts on which Nanny will call in case of necessity. After this you can launch Nanny with the help of the special button on the screen.
First ten seconds after launch Nanny is inactive. You can use this time to put quietly your phone on the chosen place. The advisable distance between a child and a phone is up to two meters. After having put the phone, make also sure that the microphone of your phone is not covered. We recommend putting the phone in the way its microphone will be directed in the child's side.
You have got the possibility to contact Nanny at any moment. All you have to do is to dial from the phone number that you indicated at the launch. Nanny will call you back during 30 seconds.
Sensibility level:
You have the possibility to tune the sensibility level of Nanny. The default value can be applied for the most part of devices still there are some requiring the adjustment of this parameter.
Two way talkback:
You can speak to your child with the help of the loud-speaker. It can be useful as parents? voice usually calms down the child.
SMS about low battery:
Nanny will inform you (by using SMS) about low battery.
SMS about missed calls:
Nanny will inform you (by using SMS) about missed calls.
Here are some screenshots:
Follow this links to download the Free version
And this link will allow you downloading the complete Paid version
If you have any questions, don't hesatate to ask them here.
General:
Sensibility level:
Two way talkback:
