Wireless Tether Issue
swebb
1,117
128
63
I'm using Icedhoneybun with overclock and wireless tether1.6 (white background). I can connect ok but everytime I exit it totally locks the phone where I have to pull the battery to restart. Anyone else have this problem?
You could try down clocking to factory settings before tether to see if that helps.Also so you don't have to pull battery.Plug phone into pc type
adb shell
reboot
Thanks beezy. I'll try this and let you know results.
Honeybun is a great rom. Thanks for all your efforts here.
You could also try barnacle wifi tether, it's in the market.
Where I was having problems with Android Wifi Tether, I find that barnacle works just fine, doesn't freeze the phone up when you stop the tether. I think I like the UI a bit more, as well.
