Wireless tether problems
laneharts
15
Hello everyone, I am using liquid thundersense with the newest drodspeed kernel...I keep trying to use wireless tether and my computer recognizes that the hotspot is available but then when i connect to it on the computer i get no internet connection. I am not sure what i can do here because the verizon pre-installed mobile hotspot app works fine like it should. If anyone can help me out with fixing this i would really appreciate it...I searched and couldnt find anything
Thanks a lot
Please try fixing the permissions and revolting afterwards. This usually fixes force closing apps and services not properly running.
Sent from my HTC Thunderbolt using Tapatalk. Eat Snacky Smores.
Fix permissions _ ROM manager -> Fix Permissions -> reboot
I have the same problem, I tried fixing permissions, and had no luck. Just went back to my old rom for now???
I tried the fix permission thing as well as trying various kernels...still can't get it to work for some reason...apparently there is a known fix for this but i cant find it anywhere here or on xda
This is what helped me. I am on the BAMF 1.4 rom and the latest BAMF kernal.
in Root Explorer go to /system/bin and then delete the sh and rename the sh0 to sh and then reboot. Don't delete the sh if there is no file named sh0. Make a nandroid backup first. Also, wipe wifi tether's data before trying again.
Hope this works for you.
marksains61
