Wireless vs wired
kma581
16
I've seen its taking about one hour to charge the note 10 + with the 25 wh charger. About how much longer would it take to charge it wirelessly with the same brick? Just wondering for a reference as to whether to buy a wireless charger.
I have multiple wireless pads and stands so I can put it on one while reading, watching TV or at computer. Very handy to have. Amazon has had some good deals.
Hey, what kind of wrieless pads or stands are you using? Any recommendation? I want one that could charge more than one phone.
The main things that I have read and gotten from reviews in various sites about wireless charging is that.....
1. The wireless charger itself eventually stops working or fails to charge adequately. I take this to be of the cheaper/inexpensive/ low quality versions.
2. Eventually robs and damages the life of the phones battery.
If you change your devices fairly quickly (under a year), I suppose #2 wouldn't matter much to you.
... or, you get what you pay for.
Some have complained their Samsung brand charger was bad. I've got two that are 2-3 years old.
Choetech has a dual pad wireless. I use it for my Buds and S10
Laurie2Megan
