Xoom LTE soak test on the way
sethwardo
53
5
got this in my inbox this morning
Hi.
Thanks for joining the Motorola Feedback Network. We may have a small project for owners of Motorola Xooms on Verizon. Participants must have had their Xooms upgraded to LTE to take part.
At this point, we can't positively confirm that the project will go forward, but if it does, the timing will be fast and we thought it best to prepare a group to provide feedback.
So, if you can live with some uncertainty, please take a moment to sign up here.
Thats all the information I have to share at this time. If you sign up and meet the conditions of the project -- and it actually goes forward -- more will be provided.
Regards,
and you see why some companys choose to TEST the product before it was released?
hope its true that it is on the horizon
Looks like the ICS "soak test" for the Transformer Prime has been to release the upgrade generally, then try to figure out what issues users will end up havingl[/URL]
I don't understand. If I were to remove the word "generally" from your sentence, it all makes sense. Maybe I'm smokin' crack, but it don't make no sense to me.:):):):)
Generally, as in "to everyone, all at once", as opposed to releasing to a select few who are best situated to identify and report back on issues found.
Anyone else received one for the LTE version? I've been in the MFN for a while and didn't get an email.
Sent from my DROIDX using Tapatalk
I guess everyone is adhering to the first rule of Fightclub.
Darn you TallyHo!!! I thought there would be some new or good news in here. Got my hopes up. :p
Anyone know anything more about the Verizon LTE Soak Test????
I was hoping someone would post something soon too, but guess it's quiet :( I'm loving ICS on my phone, so looking forward to it on my Xoom; especially the data usage monitor which is a feature it should have had since day 1 :)
-Mike
I received the same invitation, but after reading the requirements, I didn't fill out the form. One of the requirements was that the Xoom has a current Verizon 4G data plan. I don't have a data plan, so I will wait for the final release.
Sent from my 4G Xoom using Tapatalk.
How long ago did you receive the request?
Things have been quiet on the LTE Xoom forums.
Sent from my Epic CM7 Android via Tapatalk
I suspect we may hear something as soon as tomorrow about the Verizon Xoom's, since the WiFi Xooms deployment is fully under way. Keeping my sticky fingers crossed.
I also own a wifi Xoom, and have not received ICS yet on that one either.
OK, I lied. I just went and checked my wifi Xoom, and the upgrade was ready to install. It took five minutes, and everything is working great!
Verizon has to sign off on the 4G LTE Xoom update. So, it will take a bit longer...sadly. I wouldn't bet on seeing it this week or even next. It's not impossible, but, I'd not get my hopes up.
Makes a lot of sense. Wonder if there is a way to find out if its in their hands?
Taking into consideration VZW has to sign off on it, I'd give it another month to two.
It's a good question. I would have to guess that yes, they have it. For how long? I don't have a clue. But it's not much more than the WIFI update with the LTE radio files included afaik. I don't think it'll take nearly as long as their phone testing usually does.
Taking into consideration VZW has to sign on off on it, I'd give it another month to two.
No, I don't think it'll take quite that long. As I just said, it's not the same as phone testing. They just have to verify that the new radio files don't break the network. Other than that, it's still a GED so, as long as it doesn't blow stuff up, it should get released fairly quickly.
