ZAGG invisibleSHIELD for HTC Evo 4G (Full Body) + Bodyglove cae
dougeetx
Pimpin' Ain't Easy
Jun 11, 2010
331
6
If I put this shield on, will my bodyglove still fit? I was wondering if it's just that much extra space that mybodyglove won't fit. Thanks!
I dont know about Zagg but I got SGP STEINHEIL ULTRA CRYSTAL and have no problem, I also emailed Zagg and asked the same question they said it should not be a problem. BUt I only asked about screen protector not full body.
I had this setup on my bb. Different device but same case and an is. You may get some small ripples after a while on the edges but since the case snaps over the shield you won't notice them.
I have full body Zagg and the Seido Innocase on. It fits. Barely. Its a struggle to get it on or off. If you're one a constant battery puller or you switch out SD cards a lot, it may be a problem.
I have a ZAGG and Seido case. Its a tight fit, but nice.. Phone feels very protected. It will fit in the BodyGlove, Ive seen a friends done.
