Zerolemon 1000mAh Battery!
AlfBriggs
197
Has anybody used the Zerolemon 1000mAh battery, thinking of getting it, reviews say 2 days very heavy usage, 3 and a half medium and 5 days if used lightly. I have a 3400mah one which is just from extended but same size and it's really good and with my stock battery (lasts a day), extended battery 3400mAh (1 day and 3/4, I don't know why it's a lot more) and this Zerolemon Battery which would last me around 3 and a half days I'd say I wouldn't have to charge my phone for nearly six and a half days plus I have a Power Bank 3500mah which adds about a day on stock battery and 3400mah. I could probably if battery time is right on Zerolemon squeeze near a week (turning off phone from 11pm to 8am every day). This before probably charging the Zerolemon Battery till full then the 3500mah in a night I get back at 6 so this is no problem for charging up even if I'm not dead. I can charge my stock battery in the Samsung Battery Charger and Power bank by plug. I understand Zerolemon battery time could vary and I could be wrong but you it sounds insane right! Even with heavy usage 5 days may be possible (all 3 battery's+power bank). I have no complaints with the stock battery its amazing however I love experiments like seeing how long my battery lasts and this will be amazing! Zerolemon here 3rd September.
All I can say is this: A lot of people like Zerolemon, so if that is something you would like to get I would say do it.
I believe you mean 10000 mah lol.
Anyways I have it and I'm quite happy with it. Normally I will get 1 day and 12 hours on battery with about 10 hours screen on time. This is what I get on average till my battery drops to around 20% and that is pretty much 2 full days for me.
Basically, I unplug it when I wake up and don't need to charge it till tomorrow night before I go to bed. I will provide screen shots of what I got when I first got the battery, but I have not been able to get such good results as these since after about 3 weeks of initial use. However, if you are looking for 2 full days of heavy use then this is the battery for you!
Posted via Android Central App on my Note 3
Anyone have a photo of the 10,000 mah battery installed on the note 3? Curious about how clunky it is.
Thanks
It's huge - and if you do a Google search on it, there are tons of images of it on a Note 3
I've paid to have faster delivery as he hasn't shipped yet after seeing a different thread praising this. Add some more screenshots???
Yes it is huge. Looked at YouTube unpacking video. Battery comes with case for entire phone.
From a svelte elegant phone to a brick. For myself that may not be worth the extra bulk.
Thanks!
Okay here's another screen shot. Not sure why the screen on time was so low because I usually get well over 10 hours on a full charge. I guess some rogue app must have been the culprit here.
That's still more than double normal and the one pet hate I have about Android is rogue apps.
iPhone is just as bad - have seen many iPhones lose battery life over time, requiring a reset to factory to fix the problem. The issue isn't unique to Android. Same thing happens with BlackBerry as well.
I get about 2.5 days on my zerolemon and around 16 hours on screen time. Which is awesome considering I use my phone moderately to heavy.
I've seen on average the stock note 3 battery gets about 5-6 hrs on screen time so to get about 16-17 hrs is about right.
And go to YouTube and search note 3 zerolemon. A ton of reviews and videos on it.
sent from my Galaxy Note 3 via Tapatalk
Had mine since they first came available on my note3.
Yes, it's big and heavy. But it does put my phone into what I think of as a useful range of two days use. Couldn't make a full day on the stock battery.
That being said: At over three times the claimed battery capacity, you'd expect that you'd get over three times the life, but I haven't found that to be the case. In my experience, it feels more like just over double the range over the oem.
I had to peel off the sticky foam from the battery cover to get it to fit, and the fit ain't nothing to write home about, to be honest. That and I had to yank the screen protector. Not only did it feel like crap and work even worse, I had a hell of a time getting the case to snap shut with it in there. Once I did that, then everything fit solidly.
I don't regret the cost, nor the utility that I get from it. I do wish that future iterations are of better quality, that would be nice.
I just purchased 2 normal sized battery and a charger for 29. Feels this is the best compromise between real long battery life and original size and weight.
I can usually get over 6 hr screen on time, this gives me more than a day usage, I don't use it as heavy as some of you guys.
I have the same thing too. But switching out the batteries became annoying for me. And it's only if I remember to carry the extra batteries and charger with me, like to work or when I travel.
For me, the best setup is having the zerolemon. Makes it heavier but I do not have to remember extra batteries or chargers (besides the stock charger)
