Zerolemon 8000mAh Battery Case for the S20 Ultra and Plus,
Mike Dee
Ambassador
May 14, 2014
23,427
292
83
For those of you hearty battery users Zerolemon has released an 8000mAh battery case. I know many of you don't want a hefty device, but it's a great way to snap on extra power on in seconds if you don't want to walk around with it preinstalled. I will be getting one for the Ultra.
https://zerolemon.com/collections/n...ltra-battery-case-8000mah-shipping-to-us-only
https://zerolemon.com/products/copy-of-galaxy-s20-plus-battery-case-8000mah-shipping-to-us-only
View attachment 317925View attachment 317926
Hey, I saw this on Amazon but it seems a little pricey vs the last couple i bought so I may wait a little while and hope it come down a bit...
Thanks
Based on quick search, it seems like the lower prices ones are the lower capacity. Good deal on a 5000mAh for the S10s at 20 bucks. The 8,000 to 10,000 are generally more.
I'll ask around if there are any promo codes.to be had.
Thanks
I'm sure I'll buy it as I will no doubt need it when I start traveling again. 8,000 is much larger as I have 2, 5,000 ones for my S10 that I just traded in...i guess they will go on ebay...thanks Mike!
Too bad it doesn't support DeX. The Note 10 version does.
I was told by Zerolemon that it does support DEX but after your post I read the fine print and it says it doesn't so I will try to get a clarification.
The website also says it doesn't support Android Auto but the rep said it worked on the vehicle they tested.
The Amazon reviews confirm that DeX still works. I ordered one.
I have a zerolemon 15000mah power bank Ive had it for a couple of years still works good
i think i would jus buy a power bank, before i put such a big back end case on my phone. but then the cables i kno, hmm, i may actually rethink that, but then having to switch between cases, oh well, i guess it works for some people.
I know people who use them full time. Not my thing but I could see the practicality in certain situations. My daughter asked if I could pick one up a couple of weeks ago for her Spring Break trip on my way home for her 11 Pro Max. Luckily I was home and it saved me 129 dollars.
I received mine. So far it works great except for Dex. I got Dex on PC to work but it doesn't work if I connect it directly to my Asus monitor with a USBC cable.
60 quid for that mongo zero lemon battery... that's definitely paid for then..
Just received mine, a little larger than the past models I have had in the 4000-5000 mha range but I expected that with 8k capacity...but back up is back up...
jhie
