ZeroLemon extended battery case
Ronan1287
103
So does anybody have or have used this for the GS5? I used to have one for my S3 back in the day and it worked amazing. I'm contemplating buying one for my S5 so I can get as much battery life as I can. However, I am noticing a good amount of reviews saying their phone exploded... So not so sure I wanna do that! :eek:
Typically those that had the exploding phone were using a cheap, 3rd party replacement battery in their phone.
But it's always a fear when also using a 3rd party battery pack.
I have the Zerolemon 8500 mah battery and case and have had it for about a year now. The battery is great. The only problem I have is the belt clip is kind of brittle. I had several replaced for free under the 180 day warranty. After the warranty is up you are screwed if you break it. They won't even sell you a clip separate. The only way to replace the belt clip after the warranty expires is to buy a whole new setup and battery. My belt clip is currently working fine for me thanks to some tape, epoxy, and superglue.
With that said, I do really like the battery and it does allow NFC to work unlike some others.
Steve
*Please note this battery requires removal of the back cover which will not sustain the water resistant design of the Galaxy S5.
It's really a pity that the ZeroLemon designs don't incorporate this feature.
kiki2025
