ZVH / GingerBread charging and mass storage workarounds
sfhub
2,384
741
I don't have a Optimus to test this on anymore so don't shoot me if it doesn't work. Just trying to help.
From my analysis of the problem...
If you boot into recovery or leave the phone off, it should charge.
If you are rooted and have Xionia installed, you should be able to do "mounts and storage"->"mount usb storage" (stay in that page after selecting, don't exit until you want to disable mass storage)
If you are rooted and want a quick way to boot into recovery Quick Boot from market works:
https://market.android.com/details?id=com.siriusapplications.quickboot&hl=en
These aren't necessarily great workarounds, but if you can't charge at all or can't access the USB from your PC to retrieve files and don't have a reader, it is better than nothing.
Ivy547
Active member
Mar 21, 2011
43
I've had many issues with the update, one of them, the USB not connecting. I did download the driver from LG and voila! It works... If everything else was as easily solved. Thanks for the post BTW.
sstagl
