I realize there are numerous threads on this but none really address a couple of primary questions for those looking to resolve the battery life issue with the Thunderbolt, when the phone will reside in a full wrap around case like the Trident Aegis.
Needless to say cases like the Defender, Kraken, Aegis, Incipio etc. require some time to dis-assemble to change a battery. Dis-assembly is not a deal breaker but not something I want to do regularly.
1) So assuming I don't want to dis-assemble: Has anyone explored a solution like the Kensington Pocket Battery (or similar)? Pocket Battery for Smartphones - K38056US - Kensington This is an intriguing solution as it doesn't require taking the phone protective case apart to change a battery, and 3.5hrs is probably sufficient to get to a location where I can recharge.
2) Assuming dis-assembly: Which manufacturer makes the highest quality, best value after market std battery?
2.1) Are there any REAL extended "slimline" batteries that don't require an over sized battery cover that actually provide some additional battery life?
Thoughts and input appreciated.
