I know the multimedia dock will be compatible with the extended battery, but is the car dock compatible? Does anyone have them so that they can verify?
I was going to say, that too.. it most likely wont fit the car dock as I have one.. and it's a tight fit as it is... unless the 1600mah battery will fit the same cover without needing a bigger back cover.. then it will but anything bigger most likely wont.
I was going to say, that too.. it most likely wont fit the car dock as I have one.. and it's a tight fit as it is... unless the 1600mAh battery will fit the same cover without needing a bigger back cover.. then it will but anything bigger most likely wont.
So.... is it reasonable to swap batteries before using the TB for navigation in the car dock?
I hear the back is not easy to remove. Plus I suppose it requires turning the device off and then waiting for start up. That must also take a while.
Is that something people see as reasonable for the average user, or do TB owners need to wait for a 3rd party accessory to fill in the gap?
(I'm not a TB owner. Wanted one, but am waiting to see how the battery stuff shakes out, and hopefully what the Bionic looks like once more rumors hit.)
