1. devindpotts's Avatar
    Can anyone recommend a good car dock that has room to handle the extended battery? I've found a couple online but none of them say whether they will handle the extended battery or not. Thanks.
    04-08-2011 07:33 PM
  2. Chrisy's Avatar
    I haven't found any. I just keep my stock battery and door in my console for when I use my mount, which is on longer trips.
    devindpotts likes this.
    04-09-2011 08:04 PM
  3. anon(220176)'s Avatar
    I do the same, but I really hate opening the battery cover for the Thunderbolt... it's so hard to open!
    04-14-2011 12:25 AM
