10-18-2011 07:38 PM
75 123
tools
  1. tcapote's Avatar
    I have to say I love my Seidio Active Extended too.
    Ever since I put it on I haven't taken off my extended battery.
    I just received my Sedio Active Case for Extended Battery, one word: FANTASTIC.
    Seidio ACTIVE Extended Battery Case (fits 2750 / 3200 mAh) for HTC Thunderbolt
    The dual component design is flawless, perfect fit. All ports line up perfectly. Great feel and quality. Very Happy!
    Ordered from the AC Store, they shipped it out the same day I ordered it. Nice job!
    06-11-2011 11:23 AM
  2. RichardClark's Avatar
    What's your thought on the built-in kickstand with that case? How is the speaker sound affected?
    06-14-2011 06:44 AM
  3. RetiredJedi's Avatar
    The built in kickstand feels kind of cheap but I LOVE the case. The sound doesn't seem to be effected. I use my speaker phone a lot of times while driving when I forget my bluetooth earpiece and have no problems hearing. Videos and game sounds are the same also.
    06-14-2011 08:08 AM
  4. DevilJack's Avatar
    I have the Sedio two piece cover for the stock battery It came with a Holster bought it @ Bestbuy..If I get the Extended Battery cover by Sedio can I reuse the Holster I have? I ask because they sell them with or without the Holster.
    06-19-2011 10:49 AM
  5. delynnie's Avatar
    Originally Posted by boythatkills
    Verizon is now selling one of the high gloss TPU cases with extended battery support. I got mine yesterday.
    I really like the looks of the case. Do they have a holster for it? This sort of hard skin would be good for people who keep their TB w/extended battery in a pocket.
    I use my Seido surface holster, and it works great!!!
    06-21-2011 08:38 PM
  6. seidioseidio's Avatar
    Hello! You will need a different holster if you purchase an extended battery. Each case has a different corresponding holster - PM me if you have additional questions about your specific situation.
    06-22-2011 09:58 AM
  7. Xxw0lfxX's Avatar
    My platinum brand holster fits my extended battery TPU case
    Sent from my ADR6400L using Tapatalk
    06-22-2011 10:06 AM
  8. mrtonk's Avatar
    From the reviews ive seen, the cases are exactly how i thought they would be. Im gonna go ahead and order this one HTC Thunderbolt Rubberized Case with Extended Battery Support . Cheaper, covers the entire phone unlike the Surface case, not a huge amount of bulk, and i can use my kickstand.
    My big question is, is there a holster I can use with this? I also have to apparently purchase the Seidio Convert combo if I want to use a holster with a case like the Active case.
    07-02-2011 09:23 AM
  9. mrtonk's Avatar
    Is there a holster for this? There appears to only be holsters for the Convert and for the Surface.
    07-02-2011 09:25 AM
  10. jlmassey's Avatar
    I mean wtf. Why did they cover the speak and kickstand up.. I really hard to believe that it doesnt affect the sound.. I mean really comeon.. its covered up!
    Also does anyone know of a leather pouch with buckle ( magnet / snap / whatever ) not a holster, with the extended battery support
    07-04-2011 06:06 PM
  11. deepo's Avatar
    I took an Xacto knife and cut a couple of "gills" on the sides of my silicone case just where the battery hump stretches the case. Works fine although ultimately I'll get a proper case. At least I can use the old case for a while. I'm surprised - usually the accessory folks come out with a million and one extra things to buy. You've thought a series of cases to fit the extended battery would be simultaneous. Someone in marketing wasn't thinking!!!
    07-15-2011 12:29 PM
  12. ShelJW's Avatar
    Not sure if this case has been mentioned, but I'm really liking it!
    Picked up from the local Verizon store. Leaves the kickstand/speaker exposed with easy access!
    (Just noticed that the photo above doesn't seem to be for the extended battery, but the case I picked up looks EXACTLY like this one, but has the hump and is designed for use with the TB extended battery from Verizon.)
    07-16-2011 10:36 AM
  13. Xxw0lfxX's Avatar
    Just picked mine up lastnight, love it!
    07-20-2011 02:54 PM
  14. jmayniac's Avatar
    You got this from a Verizon store? Every store I have been to doesn't have anything like this for the extended battery. I can't find it on the VZW website either.
    07-21-2011 03:59 PM
  15. lapo's Avatar
    Found a great case for the thunderbolt with the extended battery. Its a rubberized hard shell case that lets you still use the kickstand that is on the thunderbolt. The website i got it from was letstalk.com and its a perfect fit that fits in my platnium holster i got from best buy.
    08-08-2011 10:12 AM
  16. masterxchief's Avatar
    Would you mind posting some pics of the case and the item number?
    08-12-2011 02:12 AM
  17. SpaceHippie's Avatar
    I have the same one. I like it better than seidios because there is less bulk, you can use the kickstand, and it feels better in hand. It's awesome!
    08-12-2011 12:38 PM
  18. Eclipse2K's Avatar
    I'm wanting to know the same thing. I would like to get an extended battery but it's too big to feel comfortable in my pocket. And I'm not a clip fan, it has to be a pouch.
    08-13-2011 06:17 PM
  19. fresefrog's Avatar
    Trident case (tridentcase.com) just released the Electra case which comes with an integrated screen protector, holster, and extended battery. It is listed for $69.95 but when I added it to the cart it came up for $64.95. If your not in a hurry they also are offering standard shipping for free.
    09-16-2011 07:05 PM
  20. Bond32's Avatar
    https://forums.androidcentral.com/e?...token=fGiHYtW0
    Sweet!!! Always love the regular one. Still doesn't beat the active extended case...
    09-16-2011 08:10 PM
  21. LAKingsDru's Avatar
    I have this same case. It's great. Also have the silicone one where you fit your phone into it.
    09-17-2011 03:26 AM
  22. Soul TKR's Avatar
    09-17-2011 05:17 AM
  23. swieder's Avatar
    Hello,
    We are glad that you liked our case! The reason why we chose to build our own is because we want to preserve the optimum viewing angle for your ThunderBolt. Building the kickstand into the case ensure that the additional thickness will not affect how you watch contents. Covering up the kickstand also maximize the protection for your device.
    Regards,
    I carved out the plastic on the Seidio Extended case so that the stock kickstand goes thru. Much nicer than the flimsy plastic stand that came with the case.
    EDIT: Pics attached, blurry, but you get the idea.
    09-26-2011 03:27 PM
  24. math2life's Avatar
    There is a guy with userid moretalktime on eBay that sells a pretty inexpensive high quality TPU case that allows for use of the kickstand too.
    10-18-2011 01:22 AM
  25. taylorz_412's Avatar
    i just bought the trident electra from trident.com and it was way to big and heavy for me
    10-18-2011 07:38 PM
75 123
