1. elai1108's Avatar
    Has anyone bought the Trexcell 1700mAh battery?
    Just curious how it performs compared to standard.
    Amazon.com: Trexcell 1700mAh Extended Battery for HTC Verizon Thunderbolt 4G LTE MyTouch 4g: Cell Phones & Accessories
    Thanks for any input!
    05-20-2011 10:21 AM
  2. Astrodroid's Avatar
    Check this out. This guy set out to test cell phone batteries against their advertised mAh ratings. He found that OEM batteries were very true to their ratings - within a few percentage points off - while the aftermarket batteries were not. In some cases the aftermarket batteries cost twice as much, advertised hundreds of mAh higher and yet delivered less than the OEMs. And the fake OEMs were even worse.
    So for example the Nexus 1 came with an OEM battery rated at 1400 mAh. It actually delivered 1357 mAh, or 97% of what it claimed. It cost $25. Meanwhile Seidio offered a battery of the same size rated at 1600 mAh for $50. But it only delivered 1305 mAh or 82% of advertised. So that's double the price for a lie and slightly worse performance. Busted!
    You can look through that chart and see very similar results. I guess it makes sense. If the OEMs could get more power out of the same size battery, why wouldn't they? I don't know anything about Trexcell, but based on these findings I'd be skeptical when someone else claims to be able to get more juice out of the same size battery.
    05-20-2011 11:12 AM
  3. BBerry2ADroid's Avatar
    I just bought these: Amazon.com: Trexcell HTC Thunderbolt 4G 2x1700mah Battery + Charger (Also compatible with MyTouch 4G): Cell Phones & Accessories
    So far the battery life is not good. I have been off the charger for 2.5 hours and am down to 43% with normal usage. I will let this battery drain then switch to the OEM battery and do a comparison.
    If it is a big difference in operating time, these will be going back.
    06-23-2011 10:29 AM
  4. SoDev's Avatar
    If you are going to go cheap go way cheap and get the 3 1500's and a wall charger for $12 on ebay.
    06-23-2011 10:51 AM
  5. BBerry2ADroid's Avatar
    ...and my battery just went dead. I got 3 hours and 53 minutes from a 1700mah Trexcell battery.
    06-23-2011 11:55 AM
  6. SoDev's Avatar
    Ouch, but thanks for letting us know. Seriously mine have been great. Maybe try those next.
    I'm not affiliated, got this link from a member of the forums, just a happy customer, so I try to help others save money.
    You can get 3 1500's and a wall charger for $12 bux. I can't tell the diff between them and the stock battery.
    3 BATTERY+DOCK Charger For HTC Thunderbolt 4G VERIZON
    06-23-2011 02:31 PM
  7. spectre1006's Avatar
    i saw a 1800 mah that still fits in the door on ebay:
    1800mah Extended Battery HTC Thunderbolt My Touch 4G | eBay
    anyone try it yet?
    my gf loves her tbolt but hates her battery life... i would buy it if it actually works...
    06-23-2011 10:17 PM
  8. milwaukee613's Avatar
    Hey guys, I just bought from amazon the 2x1700 batteries.
    I want to test them to make sure they truly are 1700mAh...
    How do I test the battery? App? widget?
    I wouldnt be surprised if they arent 1700, but nevertheless how do I test to see??
    08-04-2011 04:20 PM
