1. shloime's Avatar
    Is there such a thing? Or any company is planning on making one?
    06-13-2011 11:16 AM
  2. robrecht's Avatar
    http://www.fommy.com/view-full-page....es&skuno=80314
    http://www.thewirelessboysonline.com...ntal-case.html
    Oops, just saw that you're looking for a case for the extended battery.
    Thanks, Robrecht
    06-13-2011 01:08 PM
  3. shloime's Avatar
    the second and you tube link dont have anything to do with thunderbolt. the first is a pouch
    06-13-2011 10:31 PM
  4. robrecht's Avatar
    You and I must be looking at different websites. The last two links in my post were not working because of forced line breaks. Try again. As for the first, its a horizontal flip case, not a pouch. That said, I can't say if any of these will work well with the extended battery--I missed that part of your post.
    Thanks, Robrecht
    06-14-2011 09:02 AM
