thanks a bunch!
so just some extra clarification about #2, I'm guessing the htc kernal that is baked in will override the zigg kernal i have right? You mean, just let the rom do its thing i'm assuming.
to flash the radio combo, i take the file "PG05IMG.zip" and place in root of sd card, and boot into hboot. hboot detects the zip and loads it automatically right? (havent yet flashed a radio)
another thing to confirm, to flash the radio combo, when done flashing the rom,
(a) is there a way to boot into hboot from recovery or
(b) do i let the rom fully load and then reboot into hboot or
(c) can i load zip from sd card in cwm (or maybe i'm wrong and radios can only flashed in hboot)?
last time I flashed a different rom was about a year ago, was on bamf cubed and went to forever 1.10, only thing involved was to erase the extras folder from sdcard. Since i'ts been a while, i need to be refreshed, so in the most basic way, here are the steps i need to take to flash NuSense, correct? (please correct me if wrong, or if you or anyone has additional tips to add)
1) Ti-backup + nandroid current running rom
2) boot into recovery, clear cache, clear dalvik, & factory data reset (some recommend doing these more than once)
3) flash NuSense rom from sdcard via load zip from sdcard in cwm
3a) how do i get to hboot from cwm in order to flash radio combo (can i press volume down and power in recovery, will that boot into hboot?)
4) let the rom fully load, wait for the blue lockring to show
4a) flash the radio combo now if couldnt in 3a
all help is appreciated to the fullest!
