mightyfacundo
Re: ★ ☆ | ROM | NuSenseROM | ICS Sense 3.6 | BEATS AUDIO | XLoud | Beta | ☆ ★
Please don't think this is a stupid question, but did you check to make sure that mobile data is turned on? Sometimes with the ROMs based off the leak, the mobile data gets turned off. If it's on, try rebooting. If that doesn't work, go into recovery, flash superwipe, and then re-flash the ROM.
