I just purchased a micro USB Male to USB A Female adapter so I can access a thumb drive or plug in a USB device for use with my tablet and it doesn't seem to fit into the port. It slides in and out real easily and when I plugged the thumb drive in there was no response from the tablet. The thumb drive has a light which shows when it is being accessed but it did not light which leads me to believe that my adapter is either faulty or the wrong type. It was only a few bucks from Amazon so I won't be sending it back but I do want to make sure I buy the correct adapter the next time. Thanks in advance for any and all post.
