04-24-2018 04:25 PM
31 12
tools
  1. Doug Forguson's Avatar
    I've been fighting this for a couple of weeks on my S7 Edge and I just figured it out. It is a malware issue - Google malware. The ring tones I set in my ring tones folder are still there - they just aren't accessible anymore. Apparently there is now a logical "My Drive" that is the only storage accessible. About sick of Google being so invasive. You guys don't need to see every file I own or touch. A little too big brother for my taste. Please back off and let me manage the files I put on my own device. If you want to own my phone then rent it to me instead of selling it. I don't want my ring tone files in the cloud managed by you.
    itali79 likes this.
    09-14-2017 02:06 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Where are you seeing this "My Drive"? Is this when you're trying to select a ringtone? If so, does the interface seem different? That can happen if you mistakenly choose a 3rd party file manager app when the phone asks you how you want to look for ringtones.
    If you use My Files (or any other file manager app), go to the root directory -- is there still a /Ringtones directory? If so, are you saving your custom ringtones there?
    09-15-2017 04:48 PM
  3. Carmino porco's Avatar
    My experience I'm fairly new to Android my incoming calls don't ring I'm in my 3rd zte from MetroPCS
    12-03-2017 03:08 AM
  4. itali79's Avatar
    Same exact thing here. I'm on a stock pixel XL and the only thing I can think of is that my Waze app has been locking out Google Assistant for months up until a recent update. Going to try uninstalling it.
    01-22-2018 04:29 PM
  5. TETHO2018's Avatar
    Thanks for the tip, I reset all my Apps notification to NORMAL and the problem is solved....just like that!
    03-16-2018 08:10 AM
  6. Stang68's Avatar
    Could you please elaborate on that?
    04-24-2018 04:25 PM
31 12
  1. Trying to stop my screen from waking up when I receive a text
    By jsiddle2025 in forum Samsung Galaxy S5
    Last Post: 12-24-2016, 12:20 AM
  2. [APP][2.3+][v1.0] Voicy Notifier - Let your phone speak
    By 3afrit in forum Android App Inventor
    Last Post: 08-14-2014, 03:55 AM
  3. Blue Led light won't turn off
    By Agnese Korsaka in forum Ask a Question
    Last Post: 07-17-2014, 04:22 PM
  4. How do I recover everything from my phone?
    Last Post: 07-16-2014, 07:37 PM
  5. Aol email won't sync
    Last Post: 07-16-2014, 05:35 PM
