System volume keeps reseting itself ??
rorkin
64
I have se the system volume to off in order to stop the obnoxious DROID sound every time I restart
Problem is that every so often the volum resets itself back up on its own..I cant figure a pattern for this..
Anyone seen this behavior and have a fix ??
Halo
313
57
Well if you're rooted, follow these steps to turn off the Droid charge bootup sound.
1. Using Root Explorer go to etc>PowerOn.wav
2. Rename PowerOn.wav to PowerOn.wav.bak
3. No more bootup sound :)
fundragon
65
8
I have this issue also. The culprit - or at least one of them - is "Navigation". Every time I run this app - without even touching the volume button - it sets my system volume to the highest setting.
hooskins
144
5
Use the widgetsoid app and create a volume widget. It will aloow you to control all volumes, including system, without having to dig through Settings.
akbarramadhani12
