1. integral0's Avatar
    this is a noob question but I was wondering if the Charge had a missed call/text sound alert? My old dumbphone would chirp every 2 min or so alerting me that I missed a text or call. I can't seem to find an option to do so in any of the settings. can someone point me in the right direction? thanks!
    07-07-2011 03:12 PM
  2. dyslexicbunny's Avatar
    Get NoLED. Set it up how you like and problem solved.
    07-07-2011 04:50 PM
  3. shobuddy's Avatar
    Does NoLED do sound alerts?
    07-07-2011 09:52 PM
  4. mc21's Avatar
    i think you want to turn on the repeating notification sound, should be in the settings
    07-08-2011 12:55 AM
  5. dyslexicbunny's Avatar
    Yes. It is where mc21 said.
    07-08-2011 09:36 AM
  6. integral0's Avatar
    checked settings, couldn't find it. I probably should have mentioned that I'm running a custom ROM (GummyCharged). I did look into NoLED but some reports of it being a battery hog made me a bit wary. I googled repeating notifications for android also, seems like there isn't a default option within android and the popular workaround seems to be third party apps. I'd rather not install any more apps if I can help it, especially for a feature that android should have by default.
    07-08-2011 09:56 AM
  7. shobuddy's Avatar
    I'm not able to find "repeating notifications" under sound settings or any other settings. Do you know exactly where it is?
    07-08-2011 09:57 AM
  8. dyslexicbunny's Avatar
    NoLED settings -> Audio reminder
    Turn on audio reminder. Set the tone you want. And set up whatever interval and you should be all set.
    07-08-2011 11:19 AM
  9. mc21's Avatar
    youre right i dont see it there, try "missed call" from the android market. i'm pretty sure that has it but you have to set it up for each type of notification. it should be lite on battery.
    07-08-2011 02:50 PM
