[ROM][EP1F] GummyCharged GBE 1.0 7/10/11
kejar31
Active member
Dec 30, 2010
36
32
Gummy CHARGED GBE
Rev your Charge up and get ready cause this things fast!!!
Notes:
Select Settings-->Display settings-->Unlock screen-->Glass unlock to get incoming calls to show up with the AOSP lockscreen slider rather than the puzzle crap
* You MUST be on the Gingerbread leak EP1F before you can install this
* You MUST wipe before installing this
AppWidgetPicker causes issues with The Power Control widget (not the one in the dropdown) if you use this widget put it in place and on next reboot and it will no longer be blank...
TeamGummy
Primary Dev and Themer - Kejar31
Dev - syaoran12
Extra Themes - GunnerMike53
Wallpapers - designbydaank
FABOLOUS for allowing me to use his Server to host Gummy Charged and letting me use his toolbox script to make mine!!! :)
Thanks to B16 for letting me post on his servers
Thanks to Teamdouche for publicly posting the CM source, which I compiled some of my apps from.
A huge thanks goes out to syaoran12 who was a huge part in this release. He truly deserves the tital of Dev on the team!
Features:
- Most all apps were built from source.... rather that decompiled and hacked apps via APKmanager!!!!! To do this I took the CM7 source trees and reworked the framework to allow apps to properly find resources after they were compiled.
- New Base built on top of EP1F
- The only apps left from TW are Dialer, Contacts, Camera and Browser
- AppWidgetPicker - built byboombuler
- Ads blocked via hosts file -thanks to delta_foxtrot2
- 1% battery increments built in (Icons made by me)
- Themed Dialer, Contacts, Keyboard Task Manager by me to integrate into the stock GB look and feel
- AOSP lockscreen
- Reboot options (recovery and Download)
- Overscroll Glow
- Screen off animation
- DSPManager included!
ToolBox:
-install removed TW apps:
MediaHub
TW Email
Visual Voice Mail
AllShare
TW Calculator
TW Video Player​
-Add and remove Ads
-Install Themes:
Gummy Pink
GummyBlue
GummyRed
GummyYellow
GummyComb - many images were used from HoneyBread so I want to make sure I give that author credit (haxzamatic - you da man!)
Black Alian
Pinkie​
More to come...
Known Issues:
1. Battery history is not working ( FC if you try to access it from SpareParts)
2. People are having issue streaming Pandora and Google Music
Disclaimer:
I nor anyone in TeamGummy take any responsibility for what this ROM or its tools may do to your phone.
Download:
MD5SUM
d3f0e7ab0aa59f758518ef8ae07f4433
GummyCharged GBE 1.0 - only at RootzWiki
Updates:
Change Log:
Install:
make sure you have root and Clockwork recovery installed
-boot into recovery via Recovery
-select "wipe data/factory reset"
-select "Yes -- delete all data"
-go back
-select "install zip from sdcard"
-select "choose zip from sdcard"
-find and select GummyChargedXX.zip
-reboot
Install Themes:
-find and select GummyXthemeX.zip
-reboot
Accessing the Toolbox:
-Open Term
-Type "su" (give root permissions if asked)
-Type "gummytoolbox"
Update Toolbox:
-Open Term
-Type "updatetb"
Twitter:
Follow me on Twitter for Extra news and updates on GummyCharged @kejar31
Donate:
Donate if you like what I do by buying me a round of beers!
akbarramadhani12
