1. shobuddy's Avatar
    We have it as an option on our Charge's when setting an alarm. I don't' know what it does though.
    07-13-2011 09:49 AM
  2. Anderain's Avatar
    Here is a description of it: Smart Alarm Clock for Android
    I personally don't like it... The concept is cool, but overall get a better sleep using just a regular alarm. Sometimes the "early" alarm would wake me up.
    07-13-2011 09:53 AM
  3. shobuddy's Avatar
    Interesting, thanks for the reply, Anderain. I think Google pretty much knows EVERYTHING about me now. I might give it a try but don't see myself using it regularly because it has to be kept on the bed with you to work. I try to keep the phone as far from me as possible at night (on the far corner of the end table).
    07-13-2011 10:02 AM
  4. Anderain's Avatar
    Yeah definitely try it out. If I had my alarm right on my bed I would never get up!
    07-13-2011 10:50 AM
  5. akbled's Avatar
    Hmm I actually have been using my phone as my alarm recently, and I do keep it on my bed. I think I'll try this out and see how it works for me. I'm a pretty heavy sleeper so I'm skeptical.
    07-13-2011 01:35 PM
  6. Anderain's Avatar
    Actually, I think the idea behind this works better if you are a heavy sleeper. Because when the music plays or whatever else as the "pre-alarm" it won't wake you up. The pre-alarm stuff always woke me up because I am not that heavy of a sleeper.
    07-13-2011 01:53 PM
  7. winnersmw's Avatar
    Actually, that's a separate 3rd party app. What OP is referring to is the "Smart Alarm" option in the TouchWiz alarm clock that came preinstalled. All the Smart Alarm feature does is play a calm, less obtrusive noise for a predetermined time before your actual annoying alarm sounds. It's a great feature
    Yeah, that 3rd party app does look creepy xD.
    07-13-2011 02:10 PM
  8. shobuddy's Avatar
    Actually, that's a seperate 3rd party app. What OP is referring to is the "Smart Alarm" option in the TouchWiz alarm clock that came preinstalled. All the Smart Alarm feature does is play a calm, less obtrusive noise for a predetermined time before your actual annoying alarm sounds. It's a great feature
    Ohhhhhhh, nice! Definitely a good feature since I'm a light sleeper and don't need it yelling at me right away. Thanks!
    07-13-2011 02:13 PM
  9. rorkin's Avatar
    Would appreciate it more if they paid a little more attention to getting mainstream issues working like voice dial with bluetooth.. Sheesh
    07-13-2011 06:15 PM
  10. tintn00's Avatar
    Funny thread.
    07-13-2011 09:39 PM
  11. Lostinlodos's Avatar
    Absolutely love it. When I don't sleep through it. I'm a "rough" sleeper. Up down, thrashing never quite sleep. When it wakes me, it's amazing. I FEEL better
    but if it hits at the wrong time or stage; it only makes me more, i guess adapted to the noise and then I sleep through the soft newage music smart alarm AND the pounding deathmetal alarm.
    Oh well.
    02-05-2014 11:38 AM
