06-08-2012 06:11 AM
26 12
tools
  1. jmicks8's Avatar
    If you are rooted you can change the name of the file: /system/media/droidhd.ogg. I changed mine to "droidhd.quiet.ogg" and that solved the issue. There is also a animation zip file in that folder but I havent messed with that. Hope this helps...
    06-08-2012 06:11 AM
26 12
