1. piizzadude's Avatar
    I am wondering if anyone is using widget locker with your Charge? The more specific question I have is if I use it, will it disable the stock unlocker and just use WL?
    07-30-2011 11:46 PM
  2. NHLou's Avatar
    I use Widget Locker. I doesn't disable the stock lock screen. The best way I can describe it is it sits on top of the lock screen. So, if you turn off Widget Locker, your setting for your original lock screen kick right back in.
    Hope this helps. BTW, I like WL quite a bit.
    07-31-2011 08:34 AM
  3. libertao's Avatar
    I love widget locker, I have flashlight, camera, gmail, tasks, direct dial to wife's phone all from a swipe on the lockscreen.
    07-31-2011 09:34 AM
  4. piizzadude's Avatar
    Cool thanks all!
    07-31-2011 10:54 AM
