1. papa54's Avatar
    I hope this helps
    I had went thru a very tiring 8 hrs of trying to return Droid Charge back to stock,,
    i tried everything and repeated everything over n over.. but down loaded the same ED2 file again and un-packed,
    it is 531,671 KB's anything any less will not make the conversion.
    so before you spend all night going to stock, check the files size.
    ED2 back to stock works if its the right file... so, if in same jam,
    check file integrity, and after you are in Down Load Mode, Place battery in phone.
    click the start on Odin (be sure you have file in ""PDA""" !!!NOT PHONE!!!!!)
    ALSO UNCHECK AUTO RE-BOOT...
    walk off and rest.. come back.. after re-booting.
    while setting up Charge, it had already Downloaded "EE4" and started installing..
    very clean update to EE4 install.
    08-02-2011 04:09 PM
