1. specops2k3's Avatar
    I was wondering if anyone knows if the charge can do voice and data at the same time? I heard that the thunderbolt could.
    Sent from my Xoom using Tapatalk
    08-06-2011 08:00 AM
  2. atlantar6's Avatar
    It cannot
    08-06-2011 08:05 AM
  3. brocklee137's Avatar
    Over 4g, yes. 3g, no.
    08-06-2011 08:05 AM
  4. Droid3r's Avatar
    yes it can. i live in 4G territory and am able to use both.
    08-06-2011 08:14 AM
  5. fortesquieu's Avatar
    Yes, if you're using 4G, then you could call and use data. Not over 3G.
    08-06-2011 10:20 AM
  6. piizzadude's Avatar
    this is correct
    08-06-2011 12:36 PM
