1. bellesc23's Avatar
    so basically when i unplug my charger when i get up in the morning the unplug charger thing doesnt go away, and sometimes when i get into my car and plug it in the car charger it gets stuck on desk cradle...has this happend to anyone? or any ideas if i can fix it?
    08-07-2011 09:52 AM
  2. expidia's Avatar
    First thing I would try is taking the battery out for a few seconds and then plugging it back in. This reboots the system much like you sometimes have to reboot a computer.
    Then I would press the menu button (bottom left hard key)>settings>scroll down to dock settings>click auto launch> and then click on never.
    Try those steps and see if this solves your issue.
    08-07-2011 10:30 AM
