08-11-2011 11:40 AM
31 12
tools
  1. Lodingi's Avatar
    Why? is the SD Card slot gonna support 64GB Cards?
    Say what?
    08-10-2011 07:51 PM
  2. piizzadude's Avatar
    Um. I have 1.1 gigs available for apps. Don't think I ever used more than 200 mb on my Fassy. Once GB hits, we will have an additional 32 gigs for apps. Well, that's assuming we get GB. Lol.
    You said the above, I am wondering where you are getting the other 32 GB for apps from.
    08-10-2011 08:19 PM
  3. Lodingi's Avatar
    Gingerbread allows you to install apps on your sd card.
    08-11-2011 04:23 AM
  4. piizzadude's Avatar
    With Froyo I thought you could as well, but at the very least you can move them to the SD card. If you go into manage apps, pick an app and on the next screen you should have the option to move to SD card. 75% of mine are over there and not on the internal storage.
    08-11-2011 08:02 AM
  5. Lodingi's Avatar
    Good to know. Thanks.
    08-11-2011 08:42 AM
  6. Landshark's Avatar
    I still don't understand why anybody moves apps to the sd card. I have over 200 apps on my phone, it still flies, and I still have 500MB of internal storage left.
    08-11-2011 11:40 AM
31 12
