1. killatoyota4569's Avatar
    Hey guys The Phone is stuck in the PC mode or shows a cellphone and a PC and a exclamation point. I went to use odin and put the phone to stock using a file i was told. It failed everytime I tryed, and now I have this problem. I need to send the phone back to Vz, please let me know what I need to do in order to get the phone back to stock and unroot it, thank you
    08-11-2011 10:39 AM
  2. Landshark's Avatar
    Did you have the battery in the phone when using ODIN? Charge seems to need the battery in when flashing things through ODIN. Also make sure you are using a USB port in the back of the pc near the motherboard.
    08-11-2011 11:47 AM
  3. killatoyota4569's Avatar
    Battery trick worked, idk why that happend but thank you
    08-11-2011 08:42 PM
