1. TJM623's Avatar
    Never had this happen haven't installed anything new, shut my phone off one time turned it back on and for some reason I no longer have Messages,Phone, OR Contacts across the bottom.
    Applications is still there but moved from the right corner to second from the right...Tried powering on and off, restart etc. NOTHING WORKS and i can't even find anyone with same problem via a Google search.
    please any ideas i really don't wanna factory reset.
    08-14-2011 12:50 PM
  2. Droid3r's Avatar
    Go to your applications screen press the menu button and clik on (edit) press and hold your messages icon and drag it to the bottom dock do that with contacts or whatever else you want to move around
    Sent from my SAMSUNG DROID CHARGE
    08-14-2011 04:37 PM
