1. TerryMasters's Avatar
    Hopefully this will just be a quick question, but the lock screen on my Charge is starting to get on my nerves. I'll bring the phone out of standby and put it down for a second so I can punch in my PIN, only to find the screen off by the time I pick it up. It literally lasts about 4 seconds after I've hit the power button. Is there a way to change this?
    08-16-2011 06:43 PM
  2. TerryMasters's Avatar
    I was just curious if this was possible to do with GummyCharge RC, provided it's not possible to do with stock. I've now had this issue on both roms and can't find the option to change it, if there is one. I hate hitting the power button on my phone, putting it down to unlock it and the screen going off almost instantaneously.
    10-18-2011 05:57 PM
  3. Landshark's Avatar
    You can change the lockscreen timeout through TSM parts which is included in GummyCharged and Infinity ROMs. Go menu=>settings=>TSM parts=>lockscreen settings=>lockscreen timeout.
    10-18-2011 06:15 PM
  4. TerryMasters's Avatar
    I don't think I have TSM parts for some reason... I can't find it in the settings, I don't see it listed in the app drawer and punching "tsmparts" into terminal didn't bring anything up either
    I have a "spare parts" but I don't see the timeout listed there, unfortunately.
    10-18-2011 09:13 PM
  5. Landshark's Avatar
    Like I said in my last post, TSM parts is include in Infinity ROM and Gummy Charged, but I forgot to mention with Gummy Charged it is only included in version 2.0. If you aren't running one of those two ROMs, you don't have TSM parts.
    10-20-2011 12:47 AM
