1. hfdpop's Avatar
    Has anyone else noticed that it seems to take awhile once you press the green button within the dialer for the call to connect? In most cases my phone can take up to 10 seconds to connect the call. I don't think that it is a signal strength issue because my phone does not usually go below 2 bars. I am basically stock with the exception of CWM backup.
    08-25-2011 05:05 PM
  2. sv_one's Avatar
    Yes -- same here.
    08-25-2011 07:51 PM
  3. Droid.Guy's Avatar
    I've noticed this as well. Takes mine about 2 ~ 10 seconds each time. Just par for the course with Android my D1 used to do the same. Doesn't really bother me to much.
    08-25-2011 07:58 PM
  4. dressagerider's Avatar
    Yes, I have recently noticed this....along with a host of other lag issues including data problems.
    I am currently on my 4th charge and starting to think this phone is bad. It will take a major update to fix the countless issues with the charge.
    08-26-2011 10:14 AM
