09-15-2011 08:59 AM
36 12
tools
  1. Halo's Avatar
    GPS Fix is trash IMO. Sorry Piizza, no disrespect. The only thing the app does it try to keep a lock on your GPS every once in a while so that your phone MIGHT lock quicker.
    I just wish I could figure out how to edit that damn gps.conf file myself. I keep getting access denied errors.
    Where is the gps.conf file located?
    09-14-2011 04:05 PM
  2. cmgeek's Avatar
    /etc 10 char
    09-14-2011 04:11 PM
  3. piizzadude's Avatar
    No disrespect taken, isnt my idea...lol
    if you point me to the file I will be happy to post my "fixed" file
    09-14-2011 04:12 PM
  4. cmgeek's Avatar
    Piizza, the gps.conf file is in the /ect folder on your phone (not your SD card). Thanks
    09-14-2011 04:17 PM
  5. piizzadude's Avatar
    ok give me a few minutes
    09-14-2011 04:19 PM
  6. piizzadude's Avatar
    NTP_SERVER=north-america.pool.ntp.org
    XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin
    XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin
    XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin
    SUPL_HOST=supl.google.com
    SUPL_PORT=7276
    Dropbox download: http://dl.dropbox.com/u/17789768/gps.conf
    cmgeek likes this.
    09-14-2011 04:28 PM
  7. cmgeek's Avatar
    Awesome, thanks Piizza! I will try it tonight and report back.
    09-14-2011 04:30 PM
  8. piizzadude's Avatar
    I just traced the origins of fasterfix and it appears that is the only file affected
    cmgeek likes this.
    09-14-2011 04:32 PM
  9. piizzadude's Avatar
    I added a dropbox direct download to the post above
    cmgeek and MrTruckincowboy#AC like this.
    09-14-2011 04:35 PM
  10. MrTruckincowboy#AC's Avatar
    thanks man I just moved to sdcard then put in the system/etc good to go it is a little faster.
    09-14-2011 09:09 PM
  11. cmgeek's Avatar
    Thanks Piizzadude. All is well. I just made another post to describe the method I went through.
    09-15-2011 08:59 AM
36 12
