1. actionshooter's Avatar
    My voicemail and other automated phone systems are not recognizing my touchpad tones when I try to enter a password or make selections via a menu. I tried going into settings/sound settings and turning on the audible touch tones and that didn't work either. I've had the phone about two months and this just started. I haven't changed any settings.
    Has anyone had this issue or have advice on how to fix it?
    09-20-2011 04:16 PM
  2. daveytree3's Avatar
    Never had this problem with my charge.My only suggestion would be to go to settings>call settings>DTMF tones>select long.Good Luck!
    09-20-2011 07:25 PM
