1. jwalker007's Avatar
    Just recently I have noticed that if I want to adjust just the navigation volume I get the Media volume instead. I can not for the life of me make it appear anymore. I have searched the settings, rebooted and no luck. Can anybody help? Thanks
    Sent from my SCH-I510 using Tapatalk
    10-05-2011 09:14 PM
  2. gattaka451's Avatar
    There's a program called Hide It Pro that I found works great. It will show up as Audio Manager under your list of apps. Works great for changing all the volume controls. There's actually an app called Audio Manager that might work too. It doesn't have "Notification Alert" as a slide bar though, but it does have an Alerts Volume which is probably for the same thing.
    10-06-2011 08:07 AM
  3. jwalker007's Avatar
    Thanks, actually found out google updated maps to use media volume now. Had to find last version and reinstall so I could get functionality back.
    10-06-2011 12:25 PM
