1. Salil's Avatar
    There are a couple of things that are frustrating me:
    1. When I connect my Samsung Droid charge to the USB car charger of my GOgroove FlexSmart FM Transmitter my phone thinks it's an USB storage and then brings up the USB storage screen. It then takes me back to the home screen even though I am in the Navigation app. This very frustrating since I usually enter the destination in my navigation app while getting out of my apartment and then connect it to the power supply in my car when it checks me out of the app.
    2. The second problem is that most of the time my phone doesn't pair with my FM transmitter sometimes it does and sometimes it doesn't. I want that once paired with the bluetooth device it should always connect when the device is within range.
    What do I do to solve the above two problems?
    10-08-2011 10:29 PM
  2. Landshark's Avatar
    Not sure about the second one. With the first one have you tried going into menu=>settings=usb settings and changing it from mass storage to media player? Not sure it would help, but it's worth a try. And if you have usb debugging enabled you will have to go in and uncheck that before you can change the usb settings. menu=>settings=>applications=>development.
    10-10-2011 03:26 PM
