1. hkrn44's Avatar
    When I download golocker and try to use it on my phone it gives me 2 lock screens. First the golocker lock screen and then the phone lock screen. Is this is a known problem? Is there any way to get the phone lockscreen not to go away without rooting the phone? I don't have any security set up on my phone this is just the plain old lock screen which is either "glass" or :"puzzle piece"
    golocker:
    GO Dev Teams Releases GO Locker To The Market - A Lockscreen Replacement To Compliment GO Launcher EX
    11-01-2011 12:32 PM
  2. trigun123478's Avatar
    I had the same problem. You could try no lock from the market.
    11-01-2011 02:39 PM
  3. rbess1965's Avatar
    Just tried that one on my Charge and it did not work. I'm hoping all my Go Launcher programs with work on the Nexus. I'm hoping to be able to get one of those at some point.
    11-04-2011 02:25 PM
