Blah, I got the update and am extremely disappointed with this phone. This damn phone still lags (but it's a little better than before), it's freezing on me (screen won't wake up after waiting 2 minutes and pressing the power button multiple times) I'm about to pull the battery for the second time now in roughly 10 minutes of usage. The boot up time is still extremely long and it takes a very long time to scan the SD card.
But the worst offender of all, is that they didn't fix the biggest annoying glitch which was the phone not recognizing apps installed to the SD card. 80% of my apps won't load and almost all my games won't load since they are on the SD card. The phone recognizes everything saved on the internal phone memory just fine.
Every time I boot up the phone it annoyingly asks me to turn on my mobile data. What the heck? Stop asking me that! I'll turn it on when I damn well please! Can we turn this message off? What a damn poor effort from Samsung and Verizon. I need to root this thing already and have the awesome devs pick up where the failure conglomerate companies left off.
darn!! looks like yer disgusted!
phone will not recognize some things on sd card.. well if they are widgets ,, it wont...
usually one fast push on button will make changes.. i got into that mess and when i settled down and slightly pressed the power button it stayed where i wanted it....
Mobile data is used more by Google than Verizon..
when you set the ph up,, google ask for it to be turned on.. (i guess it gives Google more imput to make maps quicker)
I see all these folks with bad Droid Charges.. and so far since i got the Charge it is has never failed me. oh GPS might be off a tad when i turn it on in the house , but it gives me time to make lane changes etc .. its usually takes it a few minutes at first but once i enter my address manually its there each time. i've had my apps on sd card before and they worked but widgets wont.. and some apps wont.. its not a charge thing its whoever designed that apps fault as to where it will run...
I must add that i live in a fringe area and owned a Fascinate at first,, now there was a "Damned Phone"
it would not even update its self from eclair to froyo untill i went off mtn and downtown. wouldnt allow me to have calls in/out.. it always turned my words into he e th wa ten may language.. skipped so bad i started to crush it while someone was listening to get satisfaction for buying it to begin with.. now if anyone had a fascinate like mine was ,,,, well they would be so happy with the charge ,, they wouldnt know how to act... i understand yer frustration and hope it (the phone) soon settles down.. or maybe they will let ya borrow my old Fascinate... crap anything beats its performance...
someone here can fix yer problems ,,, they know more than i.
