1. expidia's Avatar
    I could not get my contacts to sync after the update with Act or Outlook using Companion Link which has to be used along with DejaOffice.
    I contacted Companion Link support and she said it is a known issue and they have already created a fix for it.
    She emailed me this below and I'm in the process of following up on what she sent me:
    Date:11/30/2011
    Please follow this link to correct the sync issue you are experiencing.
    USB sync no longer works after Android OS update - CompanionLink Knowledge Base
    To sync to your Native Contacts, please follow this link:
    Synchronizing DejaOffice with the Android applications - CompanionLink Knowledge Base
    Technical Support (KJ)
    CompanionLink Software Inc.
    11-30-2011 01:55 PM
