1. Plucknbach's Avatar
    Hello,
    After my GB update, i noticed whan moving apps from phone to the SD card using the Task Manager, it now shows "Move to USB Storage" but after saving the file will show " Installed on SD Card".
    Prior to Gingerbread, It used to say "Move to SD Card"
    Anyone notice this? and how to fix?
    12-04-2011 04:50 PM
