1. Jim101's Avatar
    On GB, when I take a picture the flash goes off then the screen goes black? I have to remove the battery to get the phone working again? Happens every time.............Any ideas? Can it be an app.??
    Thanks,
    Jim
    12-08-2011 10:27 PM
  2. Jim101's Avatar
    Removed the version of "Flashlight" I had and the problem went away.....
    Jim
    12-09-2011 08:23 AM
  3. dubge's Avatar
    still does it to me and i removed the flashlight app
    12-09-2011 08:46 AM
  4. W_A_Watson_II's Avatar
    Mine did this before GB, now (knock on wood) it hasn't done it (yet) after the GB update. I did notice that the flash isn't as bright as before, and it takes a darker setting to cause it to activate than it did before.
    Camera flash kills / shuts down and locks up Droid Charge
    12-09-2011 10:34 AM
