1. shobuddy's Avatar
    Thanks
    01-10-2012 09:38 AM
  2. Chocoburger's Avatar
    I tried it a few days ago, when my phone rebooted, I got the yellow triangle with an exclamation mark in the center. After that I had to battery pull, when I looked into my SD card, it did end up creating a folder with contents inside that I had specified within the ROM Manager program. But it didn't seem to go through correctly I guess?
    01-11-2012 12:22 AM
  3. Droid3r's Avatar
    Avoid rom manager at all cost
    Sent from my SCH-I510 using Tapatalk
    01-11-2012 02:59 AM
  4. VoltaicShock's Avatar
    I have heard it does not work with the Charge.
    01-19-2012 10:45 AM
  5. Midnight_Ninja's Avatar
    Some parts of rom manger work, but i cant remember which. Better to stay away from it on this phone
    01-25-2012 10:40 AM
  6. kraisydave's Avatar
    No, do NOT use ROM manager from the market on the Droid Charge. You will have problems. Install and use Clockwork Mod to do just about all the same stuff. CWM will allow you to move around from ROM to ROM, flash themes, etc...
    Dave
    01-27-2012 12:31 AM
