Does anyone know how to get rid of all these apps which I'll never use
They're draining my battery at a rapid rate
Oh, you're right, they sure do. But if you regard the app as "junk" it's unlikely you would have started it up, it seems to me.Apps running in the background have a negative impact on the phones operation IMO.
First, if you don't use the extraneous apps they don't drain your battery. Apps not in use have no effect on battery life.
The fact an app is on your phone doesn't mean that it is "running in the background."
Nope. No guarantee of this at all.... rooting and installing a custom recovery and custom rom/kernel will speed up phone regardless ...
Absolutely inconsistent with my experience with my rooted, custom-ROMed phone.The risk/reward formula for this one is a no brainer, provided you do all the homework and follow all the steps.
I think custom ROMs exist for the following reasons:If stock were the best way to go, why would custom roms even exsist?
