1. Droidit.'s Avatar
    my droid will only charge when tilting in to the charging port...
    Please help!
    edit: this doesn't always help though. Sometimes ut will start ti charge then other times it wont. It is a 95% chance it doesn't charge unless i place it in the right position (of that moment)
    Sent from my SCH-I510 using Tapatalk
    01-15-2012 11:30 PM
  2. starbuckk's Avatar
    Sounds to me like a broken plug (either wire or phone). Try a different cable if you can.
    01-16-2012 12:48 AM
  3. Droidit.'s Avatar
    okay thank you!
    01-16-2012 08:24 AM
