1. gregba's Avatar
    does anyone that uses LP as their launcher sometimes get severe delays with it?
    I do fairly often, and have uninstalled and re-installed it which didnt help.
    There are also times that when I come out of an app, the screens are blank for maybe 6-7 seconds before my icons/widgets appear. Are there any solutions to this?
    Thanks!
    02-10-2012 12:40 PM
  2. piizzadude's Avatar
    Pretty sure it is a known issue. I have it and so do others. I just swipe left or right and everything reappears
    Charged up post!
    02-10-2012 12:45 PM
  3. pauldroidr2d2's Avatar
    I'm not sure if you should anticipate any updates. The update for that was May 17,2011.
    Sent from one of the following: Galaxy Nexus, Bionic or Xoom using Tapatalk.
    02-10-2012 01:00 PM
  4. piizzadude's Avatar
    In a post on their forum they stated an update was on the way soon. I think the lack of updates are an "don't fix what isn't broke" kinda thing
    Charged up post!
    02-10-2012 01:16 PM
  5. gregba's Avatar
    Charged up post!
    that doesnt always solve the issue- very frustrating
    I hope it is fixed soon, otherwise i might switch to go launcher or something else
    02-10-2012 01:43 PM
  6. vwarnick's Avatar
    There has been no development on LP for quite a while now. I don't get the impression that there is going to be any either. The site's forums are static.
    pauldroidr2d2 likes this.
    02-10-2012 02:17 PM
  7. pauldroidr2d2's Avatar
    That's kind of my impression too.
    02-10-2012 06:56 PM
